Welcome to diyAudio.rs
Sign in to follow this
Followers 0
khachai44
Connect interface line out to Stage box
Hi,
I'd like to connect RME UCX line out to PA.
The mixer is far away so I have to connect to stage box which has XLR inputs that go to Mixer Mic input.
RME UCX line out specs:
• Output: 6.3 mm TRS jack, servo-balanced
• Output impedance: 75 Ohm
• Output level switchable Hi Gain, +4 dBu, -10 dBV
• Output level at 0 dBFS @ Hi Gain: +19 dBu
• Output level at 0 dBFS @ +4 dBu: +13 dBu
• Output level at 0 dBFS @ -10 dBV: +2 dBV
I am not sure about the PA Mixer specs or even if it has Pad on inputs.
I am sending full stereo mix, so don't want any artifacts like tonal shifts or loss of dynamics.
What is the best way to connect this ?
Is simply lowering output level going to work ?
Do I need a DI Box ?
Share this post
Link to post
Share on other sites
source is having enough cojones to drive long trace
but you really need to connect that line (high level) to appropriate input in PA Mix , to preserve dynamics
worse case would be using custom balanced attenuator box or balanced to balanced DI Box , but you can still do that
in any case - long trace must stay balanced
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
