Misljenje o phono sekciji
чика-Брка
a super, ono koga briga ........ 14K izlazne imedanse i F kriva na slici i objasnjavaju kako su dosli do napumpanih 37.1db
mislim , mozda je i super sprava ....... al' bas mi lepo da se napasuljam veceras na neku fifilisticarsku firmu
a imzenjeri - posenilili ....... il' su po obicaju pozaposljavana balavurdija u propagandom odeljenju
posle slicics a F krivom zamisliti Oprem Dobro linak sa YT , mrzi me ga trazim
  • Odgovora 37
9 hours ago, grau said:
zovite me pera kojot supergenije... atkinson merio za stereophile test, 37.1db. mnogo veci problem izlazna impedansa od jebenih 28k, mene bi bila sramota da prodajem tako nesto. a njih zabole jer su to pravili da se ubode u leben integralac.
The RS-30EQ phono preamplifier offered a voltage gain of 37.1dB, which is very much higher than the specified 23.5dB but is appropriate for moving-magnet cartridges. The preamp preserved absolute polarity (ie, was non-inverting), and its input impedance was 46k ohms at 1kHz, this dropping slightly, to 41k ohms, at the frequency extremes. The low-frequency output impedance was ridiculously high, at 28k ohms at 20Hz, and was still an extremely high 14k ohms at 1kHz and 6k ohms at 20kHz. The RS-30EQ needs to be used with a preamp having an input impedance of at least 100k ohms
Read more at http://www.stereophile.com/content/leben-rs-30eq-phono-preamplifier-measurements#odHprOfUmizdivmf.99
našao sam i ja to, još ranije, ali nisam verovao stereofilu :)
EF86 ima razne cene.
u zavisnosti od proizvodjaca, godista ... trte mrte.
6Ж32П je 5-6e komad.
nije skupa lampa za phono.
ja imam neku kolicinu Svetlana.
kod Ive su bile 6e, ali na malo vise je moglo po 5e.
koristim je i kao prvu lampu, pa izmedju nje i obrtaca faze boja tona.
milina.
i famozni Quad ih je koristio. i kao obrtac faze i u phono sekciji.
Ne to je Air Tight i gospodin Miura, miljama iznad Lebena
http://www.6moons.com/audioreviews/leben/cs300x.html
It's the brainchild of Mr. Taku Hyodo who apparently is considered "one of the best seven tube audio engineers in Japan". I wonder who the other six are. If the CS-300X is any indication, I need to brush up on my Japanese. The Luxman-of-yesteryear vibe was apparently intentional. Hyodo-San once designed amplifiers for that Japanese electronics giant.
Samo prenosim, faktografije radi.
pa jes , al je u Luxmanu radio i Tim de Paravicini ....... s tim sto se on nije bavio konstrukcijom njanjave cevne elektronike
moze se tu i tamo nesto prigovoriti Timovim uradcima , ali je zajednicki cinilac da imaju mooda
dok je CS300 - vidljivo i iz seme , ipak nesto drugo ....... pa da mi ga je i tata konstruisao
cim vidim ECC83 drajvuje EL84 , a nije neki specijalni i inventivni spoj u pitanju , jasno mi je kako moze da zvuci .........
obratiti paznju na rutu NFB ....... sitnim trikom bi se poboljsala simetrija ....... mada - mozda je tako kako je i spojeno da se kvarenjem linearnosti proba popraviti zvuk
ovo bez povratne sprege ima odziv k'o telefon
Nista im ne vredi "Brook" i ostale firme, 20-30 godina pravili bolje P-P ampove pre njih... :).
Posle zlatne ere ne otprilike nego tacno ovako idu stvari:
1. Smanjivanje "gvozdja" u ampovima. Osnovni motiv. Izbacivanje input i interstage obrtaca faze. Izbacivanje prigusnica ili svodjenje na jednu.
2. Izbacivanje ispravljacica. Upotreba dioda. Takodje posredno smanjuje gvozdje zbog toga sto nije potreban dodatni napon za grejanje ispravljacice. A i diode nemaju pad napona kao tube rectifier pa je i broj namotaj u sekundaru manji. Na osnovu toga moze se smanjiti i dimenzija mreznog trafoa. (Drugo ispravljacice se jako greju i greju, pa moraju biti vani. To ogranicava dizajn.)
3. Upotreba kondenzatora vece vrednosti u uF, posto postaju jeftiniji, dostupniji i manjih dimenzija. Kako bi se, posto su vec izbacene prigusnice, napon bolje filtrirao. To je dovelo do dodatnog "umrtvljivanja" ampova.
4. Na osnovu 1. 2. i 3. Dimenzije uredjaja su manje a i masa uredjaja je manja pa su zgodniji za transport i prijem kod kupaca
Ovo su osnovni motivi zbog kojih su konstrukcije takve kakve jesu A NE bolje karakteristike i zvucni rezultat :)
amin, ma nista samo mi pade na pamet onaj njihov model P-P sa 2A3 u izlazu interstage trafo obrtac faze itd itd :)
Da ne spominjem onaj univerzalni WE samo sa 4 x 211 od toga 2 su ispravljacice iz triode u diodu a druge 2 P-P .. ha ha
