stein Napisano Januar 10, 2016 Share #1 Napisano Januar 10, 2016 Tema za izvore gde se mogu nabaviti... Fine stvari Prva fina stvar (by Nesic): Gold Plated Speaker Binding Postshttp://www.ebay.com/itm/4-Pcs-Gold-Plated-Speaker-Binding-Posts-Amplifier-Audio-Connector-New-/370530320904?hash=item5645540208:m:mzTwuMI-M1rcaui-HM4t7NQ Nesic and Zflazar je reagovao/la na ovo 2 Link to comment Podeli na ovim sajtovima More sharing options...
progster Napisano Januar 10, 2016 Share #2 Napisano Januar 10, 2016 Druga fina stvar (by ja) http://www.ebay.com/itm/New-4Pc-Gold-Plated-Amplifier-Speaker-Terminal-Binding-Post-4mm-Banana-Plug-Jack-/400749765791?hash=item5d4e8c249f:g:BnEAAOSwnDZT2HEV Link to comment Podeli na ovim sajtovima More sharing options...
stein Napisano Januar 10, 2016 Autor Share #3 Napisano Januar 10, 2016 bolje posteno nickel-plated nego gold plated kod kontakata gold plated je samo za snobove Da, ali je problem naći "Fine stvari" sa poštenom zaštitom a pristojnom cenom... Najbolje što sam našao (cenovno okej a da dobro izgleda) 4mm sp. : http://www.ebay.com/itm/Generic-Brass-Speaker-Binding-Post-Banana-plug-jack-terminal-Nickle-plate-Lot-2-/221793309971?hash=item33a3e95513:g:4lYAAOSwv0tVcZvM RCA: http://www.ebay.com/itm/10PCS-Generic-Female-RCA-Jacks-Amplifier-Speaker-Audio-Connector-Nickle-Plated-/321014189481?hash=item4abdefcda9:g:7BAAAOxyXDhSge-g i http://www.ebay.com/itm/10pcs-Silver-RCA-Terminal-Jack-Female-Chassis-Connector-Nickel-plate-Amplifier/251299532481?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35006%26meid%3Dffe4855e24a64d8a83424bce9da706b2%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D321014189481 i http://www.ebay.com/itm/10pcs-Silver-RCA-Terminal-Jack-Female-Chassis-Connector-Nickel-plate-Amplifier/251299532481?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D35006%26meid%3Dffe4855e24a64d8a83424bce9da706b2%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D321014189481 Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Januar 10, 2016 Share #4 Napisano Januar 10, 2016 http://www.aliexpress.com/item/Hi-End-Audio-Pure-Red-Copper-Binding-High-Performacne-Pure-Red-Copper-Binding-Post-for-Speaker/1008193195.html?spm=2114.01020208.3.217.Ioqtne&ws_ab_test=searchweb201556_3,searchweb201644_4_10001_10002_10005_10006_10003_10004_62,searchweb201560_2,searchweb1451318400_6149 nikako brass i nikako nikl Samo crveni bakar ( ako necete pozlatu i bestek) Link to comment Podeli na ovim sajtovima More sharing options...
Aleks Napisano Januar 10, 2016 Share #5 Napisano Januar 10, 2016 Ne, najjači je bio onaj Markiz koji čuje značajno poboljšanje zvuka kada promeni strujni konektor. Elem, meni razlika najveća u vizuelnom meračenju. Npr ovo jeste malo skuplje, al mnogo lepo: http://www.ebay.com/itm/111796371115?_trksid=p2055119.m1438.l2649 Ako hoćete dobre elektrolite za A klasu (25V), nemoj se ni razmišljate: http://www.ebay.com/itm/221174196459?_trksid=p2055119.m1438.l2649 vrh za male pare, provereno. Zflazar je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
stein Napisano Januar 10, 2016 Autor Share #6 Napisano Januar 10, 2016 Ne, najjači je bio onaj Markiz koji čuje značajno poboljšanje zvuka kada promeni strujni konektor. Elem, meni razlika najveća u vizuelnom meračenju. Npr ovo jeste malo skuplje, al mnogo lepo: http://www.ebay.com/itm/111796371115?_trksid=p2055119.m1438.l2649 Ako hoćete dobre elektrolite za A klasu (25V), nemoj se ni razmišljate: http://www.ebay.com/itm/221174196459?_trksid=p2055119.m1438.l2649 vrh za male pare, provereno. + 7€ prevoz do Srbije ili 3.5€ unutar De. trt. Dakle, ništa na komad. Link to comment Podeli na ovim sajtovima More sharing options...
Aleks Napisano Januar 10, 2016 Share #7 Napisano Januar 10, 2016 Ništa na komad, ali 6 komada sam platio 26e, pa dobio povraćaj PDV-a 3.8e i ovde platio 100 din carinski pregled. Total 22e za 6 komada Link to comment Podeli na ovim sajtovima More sharing options...
ZZZ Napisano Januar 10, 2016 Share #8 Napisano Januar 10, 2016 evo ima i furutech lepe mini XLR http://www.furutech.com/2013/03/19/6098/ ... Imace totalno je besmisleno kupovati super ne-capacitivne konektore. AKO se tamo gde se fizicki konektor steze ne uradi dodatna izolacija. Glavno je to izolovati pre stezanja. . Probao i izmerio odsecen deo kabla samo konektor i 3-4cm kabla oko 40pF sam konektor bez stegnutofg kabla par pico F... Link to comment Podeli na ovim sajtovima More sharing options...
Aleks Napisano Januar 10, 2016 Share #9 Napisano Januar 10, 2016 budi tolerantan i prema onima koji vode racuna o konektorima Orvorite bre temu o vašim fensi konektorima koji život znače i pišite tamo. Nemam ništa protiv toga. Evo zaklinjem se da neću reč da pisnem na takvoj temi. Samo nemoj da brljate po celom forumu, svuda gde se na trun spomene o bilo kakvom konektoru/kablu, odmah se raspiše jedna ista ekipa. Napravite posebnu temu i uživajte, imate moj Blagoslov. Evo ja ću da vam napravim ---- > http://www.diyaudio.rs/topic/7855-high-end-audio-konektori-i-kablovi/ Molim moderaciju ako može i smatra prikladnim da konkretne postove prebaci u pomenutu temu. Ovo je tema o finim prilikama za kupovinu jeftinih positnica po internetu, a ne o high end konektorima. Hvala najlepše. Link to comment Podeli na ovim sajtovima More sharing options...
ZZZ Napisano Januar 10, 2016 Share #10 Napisano Januar 10, 2016 Ima i jos nekih mekih konektora http://www.google.com/search?q=Eichmann+Bullet+Plug+RCA&hl=en&gbv=2&prmd=ivns&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjhmNjP_J_KAhXps3IKHepzCUQQsAQIIA ali nelmaju odgovarajuce zenske za sasiju, to jest imaju ali je obicna konstrukcija u pitanju EICHMAN-74347http://www.partsconnexion.com/connectors_brand_eichmann.html Link to comment Podeli na ovim sajtovima More sharing options...
ZZZ Napisano Januar 10, 2016 Share #11 Napisano Januar 10, 2016 A ima i ovi Zero conn. http://www.zenn.com.sg/zero_connector.htm Link to comment Podeli na ovim sajtovima More sharing options...
prophet Napisano Januar 10, 2016 Share #12 Napisano Januar 10, 2016 Made in Srbija http://www.digitel.rs/sr/proizvodi/ Zflazar je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
skrstic Napisano Januar 10, 2016 Share #13 Napisano Januar 10, 2016 A ima i ovi Zero conn. http://www.zenn.com.sg/zero_connector.htm gde bi mogle ovakve 6mm gumice da se nađu? Link to comment Podeli na ovim sajtovima More sharing options...
Zflazar Napisano Januar 10, 2016 Share #14 Napisano Januar 10, 2016 gde bi mogle ovakve 6mm gumice da se nađu? gledaj u prodavnici za vodoinstalacije,plinske instalacije ili možda čak za auto-delove, imaju te gumene dihtunge, prstenove i slično u svim nezamislivim promerima.... Link to comment Podeli na ovim sajtovima More sharing options...
ManicP Napisano Januar 11, 2016 Share #15 Napisano Januar 11, 2016 A ima i ovi Zero conn. http://www.zenn.com.sg/zero_connector.htm Genijalno. Samo rešit oksidaciju bakra da ne mora kratim svakih 6 meseci i bole nas Od konektora sam nakupovao dok je bilo ovih http://kanibal.co.rs/products.php?sgr=12205000&pid=12205036 Tozla, bez nepotrebne gvožđurije okolo u vidu metalnog kućišta, nemagnetni kontakti napravljeni od po jednog komada tananog materijala. Kontakt mase nije zatvoren prsten, još se malko i raširi kad se navuče, srednji pin tako ofrlje i ćoškasto napravljen da dodiruje kontakt u dve tačke (skoro ko Eichmann Bullet ). Men dovoljno dobro a uveren sam da će da opere ove skupe konektore od kilo metala na frekvencijama gde je razlika merljiva E sad, da su ružni, ružni su. Link to comment Podeli na ovim sajtovima More sharing options...
Zen Mod Napisano Januar 11, 2016 Share #16 Napisano Januar 11, 2016 tema ociscena , postovi prebaceni u Alexovu temu : http://www.diyaudio.rs/topic/7855-high-end-audio-konektori-i-kablovi/#entry221503 ZM Link to comment Podeli na ovim sajtovima More sharing options...
stein Napisano Januar 11, 2016 Autor Share #17 Napisano Januar 11, 2016 Link to comment Podeli na ovim sajtovima More sharing options...
Nesic Napisano Januar 12, 2016 Share #18 Napisano Januar 12, 2016 http://www.aliexpress.com/item/1Pair-High-Quality-Brand-New-Speaker-Cable-Amplifier-Terminal-Binding-Post-RBS-4mm-Banana-Connector-Coverter/32542813323.html Stigli sa gornje adrese. Odlično stanje. Za 5.5 baksa (kad sam ja pazario), mukte. Link to comment Podeli na ovim sajtovima More sharing options...
zbotic Napisano Januar 12, 2016 Share #19 Napisano Januar 12, 2016 Evo i mojih, ni najveća konjina tu ne može ništa slomiti. Stalno su na aukcijama pa tko uhvati, uhvati. http://www.ebay.com/itm/4pcs-High-Quality-Gold-Plated-Copper-Amplifier-Speaker-Terminal-Binding-Post-/221991101819?hash=item33afb3657b:g:uI8AAOSwo0JWO1Af Link to comment Podeli na ovim sajtovima More sharing options...
stein Napisano Januar 12, 2016 Autor Share #20 Napisano Januar 12, 2016 Evo i mojih, ni najveća konjina tu ne može ništa slomiti. Never say never... zerowaf je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
zbotic Napisano Januar 12, 2016 Share #21 Napisano Januar 12, 2016 I to što kažeš.... Baš lemim chincheve na kabel od 1000 eura koje je odgrizao pas Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano Januar 12, 2016 Share #22 Napisano Januar 12, 2016 I to što kažeš.... Baš lemim chincheve na kabel od 1000 eura koje je odgrizao pas Mogao je i sa manje drame ocjeniti zvuk kabela. Link to comment Podeli na ovim sajtovima More sharing options...
