ab Napisano Decembar 3, 2015 Autor Share #45 Napisano Decembar 3, 2015 Najlepse od svega je sto je sve iz prve proradilo bez bilo kakve greske i cinculiranja Link to comment Podeli na ovim sajtovima More sharing options...
ab Napisano Decembar 3, 2015 Autor Share #46 Napisano Decembar 3, 2015 Sto se tice nabavke potrebnih el.komponenata, AMB Audio shop - spisak sledecih potrebnih komponenata: ItemsDisplay filter: Show all items By project: CK²III headphone amplifier By project: LCDuino-1 display I/O processor By project: Mini³ portable headphone amplifier By project: M³ headphone amplifier By project: α10 stereo pre-amplifier By project: α20 line amplifier By project: α24 fully-differential line amplifier By project: β22 amplifier By project: β24 fully-differential power amplifier By project: γ1 modular miniature DAC By project: γ1.5 miniature high resolution USB DAC + headphone amplifier By project: γ2 compact high performance DAC By project: γ3 high resolution DAC By project: δ1 relay-based R-2R stereo attenuator By project: δ2 relay-based stereo input/output selector By project: ε12 delay/muting/protection for headphone amplifier By project: ε24 power switch driver circuit By project: ε27 volume control pot mounting board By project: ζ1 audio widget asynchronous USB-I²S module By project: σ11 single-rail regulated power supply By project: σ22 dual-rail tracking regulated power supply By project: σ24 transformer mounting board By project: σ25 regulated power supply By project: χ1 Li-Po battery board for Mini³ By type: Circuit boards By type: Connectors, Jacks By type: Crystals, oscillators By type: Discrete semiconductors By type: Integrated circuits By type: Panel components By type: Passive components By type: Thermal management (Related projects: M³, γ1, γ2, γ3) Description Price (USD) Quantity Notes σ11 single-rail regulated power supply printed circuit board $12.00each PSU for M³, γ3 and others Aavid-Thermalloy 529802B00000 1.5" extruded TO-220 heatsink (3.7°C/W) $2.00each 4 needed per β22 board 4 needed per σ22 board 2 needed per σ11 board International Rectifier IRLZ24N power MOSFET (TO-220) $3.50pair 1 pair needed per σ11 board 1 needed per ε24 board BC546B NPN 65V small signal transistor (TO-92) $0.20each 6 needed per σ22 board 3 needed per σ11 board 3 needed per ε12 v2 board BC556B PNP 65V small signal transistor (TO-92) $0.20each 6 needed per σ22 board 3 needed per σ11 board 2 needed per ε12 v2 board Semitec E-202 2.0mA current regulator diode (DO-35) $2.30each 2 needed per σ11 board 2 needed per σ22 board Semitec E-562 5.6mA current regulator diode (DO-35) $2.30each 1 needed per σ11 board 2 needed per σ22 board BZX55C12 12V 500mW low noise zener diode (DO-35) $0.25each 8 needed per β22 board 8 needed per β24 board 1 needed per σ22 board (certain output voltages) 1 needed per σ11 board (certain output voltages) 1 needed per Mini³ board Wima MKS2 1µF 63V MKS film capacitor $0.90each 2 needed per α20 board pair 7 needed per β22 board 6 needed per β24 board 4 needed per σ22 board 2 needed per σ11 board 13 needed per M³ board 1 needed per ε12 board 3 needed for γ1 full config 1 more for γ1 USB-to-S/PDIF converter or full++ config 2 needed per γ2 board Kemet/Evox-Rifa MMK 3900pF 63V MKT film capacitor $0.38each 2 needed per σ22 board 1 needed per σ11 board Najbitnije su regulator diode naruciti preko AMB Audio shop-a jer ih necete nigde naci, a pored toga naravno i plocica. Napomena: dostava sa teritorije USA bez obzira na kolicinu i iznos je 30USD. Veci deo preostalih komponenata narucio sam iz Farnell-a: http://www.farnell.com/ Ovde obratiti paznju da se naruci ono sto je na stock-u iz EU i za sve takve dostava se naplacuje 5evra, dok se komponente iz stock-a iz USA to naplacuje 25USD. Inace, sve je preko Farnell-a profi, naruceno stiglo za 1.5dan i maksimalno profi upakovano i obelezeno. U mom slucaju, iz AMB-a sam zajednicki narucivao sa kolegom sa DIY foruma, moja kostala 30USD, dok smo postarinu od 30USD preraspodelili on 2/3 ja 1/3 zbog kolicine koju je on narucivao. Porudzbina iz Farnell-a placena 20evra. Za skutijavanje, videcemo. To prepustamo kolegi Leonardu profesionalcu. Kada leonardo zavrsi slede utisci i zapazanja. Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Decembar 3, 2015 Share #47 Napisano Decembar 3, 2015 au, koji si ti AMB ovisnik..... Link to comment Podeli na ovim sajtovima More sharing options...
ab Napisano Decembar 3, 2015 Autor Share #48 Napisano Decembar 3, 2015 Reko moze nekome biti interesantno ko se nije susretao, nije da namecem Link to comment Podeli na ovim sajtovima More sharing options...
zbotic Napisano Decembar 3, 2015 Share #49 Napisano Decembar 3, 2015 Da bude neke koristi od teme : Kako napraviti "misterioznu" i "nedostupnu" CR diodu na slijedi na linku. Prosto ko pasulj . Inače u lamentiranju ima ili nema falsifikata bolje da ste me na opasku "kako se CRdioda može zamijeniti običnim tranzistorom" pitali "kako?" Ali svejedno evo (iz altruizma) http://www.vishay.com/docs/70596/70596.pdf Inače sve CDR koje sam kupio na Ebayu su bile OK. shonne je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Decembar 3, 2015 Share #50 Napisano Decembar 3, 2015 pa dobro, ima i diy a ima i kupi lego kocku tj konfekcija rešenje. ono što je sigurno je da gorenavedene CR diode nisu jedine tog tipa a ima i boljih. Link to comment Podeli na ovim sajtovima More sharing options...
ab Napisano Decembar 3, 2015 Autor Share #51 Napisano Decembar 3, 2015 Ja se drzao preporucenog, nisam bio u situaciji da biram - lepo je znati pa makar i naknadno. Hvala za info. Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Decembar 3, 2015 Share #52 Napisano Decembar 3, 2015 nije to svakako jedino što skorije sklapaš, tako da nema veze. nekad je preporučeno dobro, nekad je i preterivanje, nekad nađeš i daleko bolje a jeftinije od preporučenog kako kad bude. u svakom slučaju kesica sa all-in-one je uvek zadovoljstvo za sklapanje. bar se ja tako sećam, a davno je to bilo. poslednje su bile ravensburger puzzle, 3000 komada daleke 70 i neke. Link to comment Podeli na ovim sajtovima More sharing options...
Zen Mod Napisano Decembar 3, 2015 Share #53 Napisano Decembar 3, 2015 ko roman od Agate Kristi ........ bez poslednjeg lista btw. moram zamolim Miku da napravi zastavu za Gundjoland , da ti prikacim Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Decembar 3, 2015 Share #54 Napisano Decembar 3, 2015 kud spomenu ravensburger... evo sad sam našo sjajnu ideju šta ćeri za poklon https://www.myravensburger.com/my-ravensburger-puzzle/index.html naravno neko će F5 u 3 iljade komadića, kako šta ko voli Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Decembar 3, 2015 Share #55 Napisano Decembar 3, 2015 evo ti bi mogo "ancient Batsch u jesen" u 3 iljade komada Link to comment Podeli na ovim sajtovima More sharing options...
ab Napisano Januar 31, 2016 Autor Share #56 Napisano Januar 31, 2016 Pozdrav svima Iako nema interesovanja za ovu temu red je da ipak postavim par fotosa ucinjenog: Cilj ispunjem, uticaj na zvuk ucinjen. Bice prilike ovih dana, nadam se, kada se ispune uslovi i da obaveze dozvole da obavimo uporedni test sa originalnim M2Tech-ovim baterijskim napajanjem i sa jos jednim DIY napajanjem by Impuls. Alek05 and Zflazar je reagovao/la na ovo 2 Link to comment Podeli na ovim sajtovima More sharing options...
Nesic Napisano Januar 31, 2016 Share #57 Napisano Januar 31, 2016 Lepo. Veličina/širina PSU box-a srazmerna širinskom rasporedu malih kutija iznad Koje si konektore pozadi koristio za (iz)vođenje napona ka odredištu? Link to comment Podeli na ovim sajtovima More sharing options...
ab Napisano Januar 31, 2016 Autor Share #58 Napisano Januar 31, 2016 Hvala, inprovizacija na temu... Konektori napojni za sasiju: http://www.mikroprinc.com/proizvodi/elektromehanicke-komponente/konektori/konektori-napojni/napojni-2.1/5.5-mm-ugradni-metalni/index.php Moja zelja bila: http://www.psp.rs/rean-rt3mp ...ispostavilo se kao nepotrebno jer je uslovljeno sa strane M2Tech kockica vrstom konektora, pa malo toga moze da se promeni kada bi se upotrebio mini XLR samo sa jedne strane. Mozda je vredelo pokusati, a nije ni naknadno tesko to izvesti... Igrao sam se malo sa Neoteck kablovima: http://www.kanibal.co.rs/products.php?sgr=15023000&pid=15023003 Link to comment Podeli na ovim sajtovima More sharing options...
zbotic Napisano Februar 7, 2016 Share #59 Napisano Februar 7, 2016 Uhvatila me volja za naštancati par tih Sigmi (dvostrukih). Jedna je još prije otišla u Dynahi pojačalo. To je tako kad se netko skrši na skijanju pa sedam dana jedva hoda i ne može napraviti ništa korisnije Link to comment Podeli na ovim sajtovima More sharing options...
ab Napisano Februar 7, 2016 Autor Share #60 Napisano Februar 7, 2016 U zdravlje. Vrati se sada struji, ona tebe nece ubiti, sport neka saceka. Link to comment Podeli na ovim sajtovima More sharing options...
