Udrobljena DAC - USB kablovska tema :rofl:
Mikorist
Sad mogu da kazem da cujem dobru razliku izmedju OS-ova.   Ubuntu Studio sa najbolje cuje . Odnosno  low latency kernel.
@Siroma
Ti kazes da srimovani naponski kabl na CD-u popravlja zvuk.
Ja kazem da srimovani USB kabl na DAC-u popravlja zvuk (u jedno je i naponski) . Sad eksperimentisem.
:buehehe:
Ajd napravi ovakav širmovani USB kabl.
Kroz jedan širmovani sprovedi napajanje a kroz drugi DATA  pa sve izlemi na kraju na jedan USB A odnosno USB B konektor pa uporedi takav kabl gde su odvojene power i data linije sa običnim  kablom.
Zar je 0 i 1 različito sa različitim kablovima? Ljudski mozak je lako prevariti.
napajanje je razlicito.
ako se ovim gore kablom brze puni telefon, onda i DAC dobija bolju struju.
ima na sajtovima za mobilne tipa forum.xda-developers.com objasnjeno zasto bas 28/24 AWG   :buehehe:
USB cables have a data wire and a charging wire within the cable itself. Most USB cables, probably over 99+% are 28/28. Buying after market micro USB cables will pretty much always result in getting cheap quality 28/28 cables and your device will barely break 500mah when it charges, maybe even less. This isn't the only issue though. After you use a cable for a while it pushes slight stresses on the micro USB connector itself and compresses it. This causes poor connectivity between your device and the wire. This is why it seems like your device port feels like it's getting loose and you think something is wrong. It's most likely the cable being slowly damaged over time. Solution? Get a 28/24 gauge cable. 24 gauge is ~ 60% larger and can handle 2amps.
SOLUTION:
1. Use a high quality, high amperage USB charger.
2. Use a cable with an AWG of (28/24) or lower. (odnosno i deblji - nisam uspeo deblji od ovog da nadjem )
3. Cables longer than 6 feet is not suggested regardless of lower AWG as the connectors itself (especially at the MicroUSB end) will be the bulk of the impedance for that cable.
4. If you desire to have "AC Charging" be displayed on your Nexus 7, short the data wires/pins. Remember, this has no effect on the charging rate.
5. If you plan to modify the charger, take a resistance measurement of the data pins first (unplugged), any readings other than 0 ohms or infinity (open or not connected), you will need to isolate the data pins from the charging circuit prior to shorting. If you do not, you risk damaging the charger and/or your precious Nexus 7.
6. If you plan to modify the cable, short the data wires at the MicroUSB end and leave the data wires open or not connected at the charger end. Use heat shrink to insulate the exposed conductor of the data wires.
7. Make sure the MicroUSB connector end is about 6.0 mm in length
Zapravo kod USB kabla utiče kakav je kabl. Ovom prilikom se ne bavim audiophool kablovima od xxx eura.
Mika ima kabl 28/24 AWG (28 data i 24 napajanje) a postoje i kablovi 28/28 AWG, jeftini i sve. Kroz 28/28 uređaj teško da povuče više od 500mA, imam čak jedan koji je ispravan a ne može da puni telefon koliko je dobar. Što se tiče napajanja sa različitim kablovima se uređaji vidno pune različitim brzinama (pod uslovom da punjač prati a uređaj mož da povuče više od standardnih 500mA za USB port na računaru). Uz tablete dolaze punjači i 2A.
Što se tiče napajanja itekako ima smisla, ne što je 28/24 kabl svemirka prepucijum tehnologija nego je napravljen kako valja (2,5x manji otpor nego 28AWG) a ovaj 28/28 je đubre.
E sad, spomenuo mi svojevremeno kolegion elektroinženjer, u non audio smislu, da USB kabl nije zezanje, velike su brzine kroz njega (400mb+ i ko zna koliko MHz treba proturiti kroz isti) i da itekako ima uticaja kako i šta je napravljeno. Na žalost ne sećam se detalja al reče da je tu zapravo usko grlo...
pa da. uz DAC sam dobio 28/28 AWG. kapiram da pakuju uz sve standardno  te iste ako ne i tanje kablice - djubre
28/24 AWG je  prilicno debo. onaj gore savetuje jos deblji od prilike treba da bude debeo kao mali prst. samo takav nema da se nadje kod nas  :buehehe:
p.s.
namerno prave i pakuju  tanke kablove - da bi riknjavalai ispravljaci , kontakti, itd... da bi se kupovali novi - unistavale baterije - pa i one kupovale. potrosacki efekt.
BTW, duže vreme već imam nameru da našvajsujem ovo probe radi.
Kablovska priča koja zvuči logično uprkos tome što nisam siguran u benefit u stvarnom životu. A opet ako se uređaj i napaja kroz isti kabl, malo veći presek napojnog kabla i manja dužina krojena po meri neće da škodi a ne košta puno da se proba ako neko radi zabave radi kao ja :)
imam i HAMA  78490  480 Mbit / s
http://www.winwin.rs/usb-kabal-usb-a-na-micro-usb-b-0-75m-zlatan-hama-78490-1147788.html
nema nikakve razlike izmedju njega i  Samsumgovog sa feritom koji je duzi za pola metra.
al ima izmedju fabrickog 28/28. po BASS-u visokim. jednostavno sa tanjim zvuci tanje . muci se da povuce vise od 500mA  :oke:
