Pređi na vezu
Slika
BB DAC - AK4396
  • Molimo Vas registrujte se ili prijavite da biste odgovorili
168 odgovor(a) na ovu temu
#121 gaggia
gaggia
    Gagica
  • Član
  • 2701 Poruke
  • Pol:Muško
  • Lokacija:Beograde, Beograde crne su ti bele ograde..
    Serbia
Odgovor 06 August 2012 - 20:55
evo vamo malo pomoci, ali znam da si tako uradio...cisto da se ima odakle poceti problematikahttps://sites.google.com/site/merlin2069ersdiyaudioprojects/Home/in-progress/ak4396-dac
Ko se pametan budi, taj glup zaspi..Rek`o mi Bbane..
#122 gaggia
gaggia
    Gagica
  • Član
  • 2701 Poruke
  • Pol:Muško
    Serbia
Odgovor 06 August 2012 - 21:02
eve i ovde smo pokrenuli malko, nadam se da ce odgovor uskoro:http://www.diyaudio.com/forums/digital-source/217469-i2s-usage-diy-dacs.html#post3116995
#123 gaggia
gaggia
    Gagica
  • Član
  • 2701 Poruke
  • Pol:Muško
    Serbia
Odgovor 07 August 2012 - 03:09
http://www.diyaudio....tml#post2976807
#124 bata bane
bata bane
    germanijum ima dušu...al' tek sto je ceve imaju...
  • Član
  • 2162 Poruke
  • Pol:Muško
  • Lokacija:Beograd
  • Interesovanja:kravlja zadnjica , skembici, rakijica...
    Serbia
Odgovor 07 August 2012 - 08:16
Evo sad pogledah.... :whistle2:
Ja sam turio direktno I2s na DAC bez tih otpornika, jel moze to da bude razlog.....da ne funkcionira :guitarplayer:
Negde sam procitao da mora da se .....
The X2 is good IF (BIG IF) you can set your computer to have a low dpc latency so the USB packets get sent on time every time.
There is some software that can show your PC's latency - dpclat.exe -
http://www.thesycon.de/deu/latency_check.shtml
Asynch devices don't need to worry about latency so if you can get the signal isolated like John Kenny's design, that's the way to go.
If you can get your latency very low and keep it that way, then an X2 can be just as good imo.
Ako neko razume, bi li mi objasnio :wink2:
ne druzim se sa ljudima koji ne vole skembice i Lego kockice...
#125 ManicP
ManicP
    električar banderaš
  • Član
  • 2581 Poruke
  • Pol:Muško
  • Lokacija:Beograd / Aradac
  • Interesovanja:igranje strujom
    Isle of Man
Odgovor 07 August 2012 - 08:42
BB, jesi skinuo/raskačio ona 4 otpora 50-ak Ohm između DAC-a i CS8416?
Nemoj silom, uzmi veći čekić.
#126 bata bane
bata bane
  • Član
  • 2162 Poruke
  • Pol:Muško
  • Lokacija:Beograd
    Serbia
Odgovor 07 August 2012 - 08:45
raskacio, raskacio i metio direk na DAC na linku koji je dao gagica ...ide i2s-otpornici-DACJel da mecem otpornici mozda...
#127 ManicP
ManicP
    električar banderaš
  • Član
  • 2581 Poruke
  • Pol:Muško
    Isle of Man
Odgovor 07 August 2012 - 08:49
A 'bem li ga, probaj... ...ne bi trebalo da su nešto preterano kritični ali imaju neku svrhu čim su gi metili tu di su.
#128 gaggia
gaggia
    Gagica
  • Član
  • 2701 Poruke
  • Pol:Muško
    Serbia
Odgovor 07 August 2012 - 09:01
proverio sam pinove i jedino me buni MCLK - ide na 3ci pin DAC-a po semi a ne vidim dir vezicu otpornika i njega.. u svakom slucaju ako je njemu radilo, trebalo bi i nama
#129 ZZZ
ZZZ
    Mačka Majda
  • Član
  • 3553 Poruke
  • Pol:Muško
  • Lokacija:bg
    Serbia
Odgovor 07 August 2012 - 09:09
Imaju svrhuAli se njihova vrednost ne moze precizno odrediti bez upotrebe osciloskopa(google signal integrity)prvo trimerom setovati R za svaku liniju a potom zameniti najblizom vrdnosti R..Ima jos nesto Svaki DAC chip ima svoje nivoe kada dostize ditalnu nulu i digitalnu jedinicui to je unutar opsega napona napajanjai to moze da bude drasticno. Na primer 1 kod nekih dacova moze da bude i na 2.7VTi podaci postoje u PDFu za svaki dac chip.Niko to ne postuje a trebalo bi primeniti prilagodjenje nivoa I2S signalaprema specifikaciji.
#130 gaggia
gaggia
    Gagica
  • Član
  • 2701 Poruke
  • Pol:Muško
    Serbia
Odgovor 07 August 2012 - 11:49
raaaaaaadiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii :wizard:
#131 gaggia
gaggia
    Gagica
  • Član
  • 2701 Poruke
  • Pol:Muško
    Serbia
Odgovor 07 August 2012 - 12:18
DAklem: teralink x2 - Ak4396
4 otpornika na ulazu u dac odlemiti sa strane sa koje prave vezu sa spdif-om. Na njih spojiti zicice mreznog kabla koji ide iz teralinka (ja secnuo za probu nekih 5cm mreznog sa sve konektorom) sledecim redosledom:
4x GND su sarene
plava - LRCK
braon - SCLK
zelena - DATA
nandzarasta - MCLK
#132 Sipi
Sipi
    Juma
  • Član
  • 5645 Poruke
  • Pol:Muško
  • Lokacija:Zemun
    Vanuatu
Odgovor 07 August 2012 - 13:22
Bravo Gagi - pride sto si priveo svrsi krepali Teralink (onaj sto se napio krvi i Ziki I Bata Banetu) :good2:
ILI LAKO, IL' NIKAKO
#133 ManicP
ManicP
    električar banderaš
  • Član
  • 2581 Poruke
  • Pol:Muško
    Isle of Man
Odgovor 07 August 2012 - 14:06
Gagica lelektričar... :wave:
#134 bata bane
bata bane
  • Član
  • 2162 Poruke
  • Pol:Muško
  • Lokacija:Beograd
    Serbia
Odgovor 07 August 2012 - 14:10
jel to bas tako ide :whistle2: na DAC pdfu prvo po redu dolazi MCLK...odozgo nadole.. a na kraju LRCKIli gresim :crying:
#135 Zvu
Zvu
    I'm gonna be Iron, like a Lion in Zion...
  • Član
  • 5927 Poruke
  • Pol:Muško
  • Lokacija:Beograd - Vidikovac
  • Interesovanja:Getting out of the Matrix...
    Serbia
Odgovor 07 August 2012 - 14:17
banderaš.... žicar :rofl:
#136 ManicP
ManicP
    električar banderaš
  • Član
  • 2581 Poruke
  • Pol:Muško
    Isle of Man
Odgovor 07 August 2012 - 14:40
jel to bas tako ide :whistle2:na DAC pdfu prvo po redu dolazi MCLK...odozgo nadole.. a na kraju LRCKIli gresim :crying:
Ne grešiš, neg ima na toj pločki i neka via i sl... ...baci pogled na sliku u prvom postu u temi, biće jasno.Ne znam zašto mi se čini da će i tvoj da svira preko I2S koliko večeraske... :wink2:
#137 gaggia
gaggia
    Gagica
  • Član
  • 2701 Poruke
  • Pol:Muško
    Serbia
Odgovor 07 August 2012 - 18:01
#138 guja011
guja011
  • Član
  • 4302 Poruke
  • Lokacija:Vidikovac
Odgovor 07 August 2012 - 18:36
čekček.. znači deklarisani krepali steramlink ipak nije krepao bar što se glavne bubašvabe tiče?
#139 gaggia
gaggia
    Gagica
  • Član
  • 2701 Poruke
  • Pol:Muško
    Serbia
Odgovor 07 August 2012 - 18:46
predmetni je muerto za sve osim i2s-a... dakle spdif, optika no passaran
#140 bata bane
bata bane
  • Član
  • 2162 Poruke
  • Pol:Muško
  • Lokacija:Beograd
    Serbia
Odgovor 07 August 2012 - 19:55
meni nece da radi..... :crying:
0 Korisnik (a) čita ovu temu
