Welcome to diyAudio.rs
bata bane
BB DAC - AK4396
169 posts in this topic
evo vamo malo pomoci, ali znam da si tako uradio...cisto da se ima odakle poceti problematikahttps://sites.google.com/site/merlin2069ersdiyaudioprojects/Home/in-progress/ak4396-dac
Share this post
Link to post
Share on other sites
eve i ovde smo pokrenuli malko, nadam se da ce odgovor uskoro:http://www.diyaudio.com/forums/digital-source/217469-i2s-usage-diy-dacs.html#post3116995
Share this post
Link to post
Evo sad pogledah.... :whistle2:
Ja sam turio direktno I2s na DAC bez tih otpornika, jel moze to da bude razlog.....da ne funkcionira :guitarplayer:
Negde sam procitao da mora da se .....
The X2 is good IF (BIG IF) you can set your computer to have a low dpc latency so the USB packets get sent on time every time.
There is some software that can show your PC's latency - dpclat.exe - http://www.thesycon.de/deu/latency_check.shtml
Asynch devices don't need to worry about latency so if you can get the signal isolated like John Kenny's design, that's the way to go.
If you can get your latency very low and keep it that way, then an X2 can be just as good imo.
Ako neko razume, bi li mi objasnio :wink2:
Share this post
Link to post
BB, jesi skinuo/raskačio ona 4 otpora 50-ak Ohm između DAC-a i CS8416?
Share this post
Link to post
raskacio, raskacio i metio direk na DAC na linku koji je dao gagica ...ide i2s-otpornici-DACJel da mecem otpornici mozda...
Share this post
Link to post
A 'bem li ga, probaj... ...ne bi trebalo da su nešto preterano kritični ali imaju neku svrhu čim su gi metili tu di su.
Share this post
Link to post
proverio sam pinove i jedino me buni MCLK - ide na 3ci pin DAC-a po semi a ne vidim dir vezicu otpornika i njega.. u svakom slucaju ako je njemu radilo, trebalo bi i nama
Share this post
Link to post
Imaju svrhuAli se njihova vrednost ne moze precizno odrediti bez upotrebe osciloskopa(google signal integrity)prvo trimerom setovati R za svaku liniju a potom zameniti najblizom vrdnosti R..Ima jos nesto Svaki DAC chip ima svoje nivoe kada dostize ditalnu nulu i digitalnu jedinicui to je unutar opsega napona napajanjai to moze da bude drasticno. Na primer 1 kod nekih dacova moze da bude i na 2.7VTi podaci postoje u PDFu za svaki dac chip.Niko to ne postuje a trebalo bi primeniti prilagodjenje nivoa I2S signalaprema specifikaciji.
Share this post
Link to post
raaaaaaadiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii :wizard:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
