Pre pola sata ubodoh eksterni hard u komp. Na kompu je bio dignut samo ACDsee.
Posle par minuta sam na eksternom hardu iz Total komandera video dva foldera
bazooka
bejacha
Prvi je bio prazan i obrisao sam ga odmah a drugi ima u sebi fajl furaka.exe velicine 201k
Folder je formiran u trenutku kada sam hard prikacio na komp i vidi se kao sistemski.
Posumnjao sam na virus i iz Komandera pokusao da ga obrisem al ne dava.
Na kompu nema foldera pod tim nazivom.
Iz Windowsa se taj folder ne vidi a opcija serch ne pronalazi fajl furaka.exe
Napujdao sam Avast u brzom skenu ali ne javlja prisustvo aliena.
Ima li ko ideju o cemu se radi?
33 odgovor(a) na ovu temu
#1
Odgovor 23 November 2011 - 09:11
lupas bzvze
#2
Odgovor 23 November 2011 - 09:33
skini trial ver kaspersky-og, pre toga deinstaliraj Avast i skeniraj
Ko se pametan budi, taj glup zaspi..
#3
Odgovor 23 November 2011 - 09:35
Moram li i NOD32 da deinstaliram?
Na ovom kompu su i Avast i Nod istovremeno aktivni.
lupas bzvze
#4
Odgovor 23 November 2011 - 09:41
Should you run more than one antivirus program at the same time?
Symantec strongly recommends that you run only one antivirus program at a time. Having more than one antivirus program active in memory uses additional resources and can result in program conflicts and false virus alerts. Your best defense against computer viruses and malicious programs is to keep your virus definitions up to date, and run Norton AntiVirus Auto-Protect. If you choose to install more than one antivirus program on your computer, then only one of them should be active in memory at a time. (The Norton AntiVirus module that is active in memory is named Auto-Protect. Other antivirus programs will have different names for this function.)
If you are running a Microsoft operating system such as Windows, Microsoft has an even stronger recommendation. The following is quoted from the Microsoft Article 189264 Plus! 98: How to Remove McAfee VirusScan
"Microsoft recommends that you have only one anti-virus program installed on your computer."
http://service1.syma...000031316555206
#5
ajaoo..skidaj oba! i nemoj vise od jednog imati...mnoogo vise stete nego koristi... skini taj trial obavezno i skeniraj, posle cemo da vidimo sta ces
#6
Odgovor 23 November 2011 - 09:42
#7
Odgovor 23 November 2011 - 09:53
Ok, jedino sto to nije moj kompjuter pa su mi ruke malo vezane.
Inace, Nod i Avast su tu po preporuci coveka koji je taj komp cistio pre 2 god od virusa.
Jedini nacin da se tada skinu zivotinjke je bio da aktivira oba antivirusa.
Guglao sam furaka i bujacha i google nista nije nasao.
Folder bazooka sam obrisao pa mi nije palo na pamet da ga guglam.
lupas bzvze
#8
Odgovor 23 November 2011 - 10:12
Mali OFF, ali na temu.
Nije zgoreg na flashovima i prenosnim HDD ima u rootu napraviti fajl autorun.ini sa proizvoljnim sadržajem (slikica u prilogu) i napraviti ga read only.
Dešavalo mi se da mi se na flash useli gamad, ali nije mogla da snimi autorun fajl kojim se startuje jerbo već postoji fajl sa tim imenom. Crowbar princip, ali zezne masu ovih primitivnih napasti.
Freedom's just another word for nothing left to loose...
#9
Odgovor 23 November 2011 - 10:18
ManicP, za 23 November 2011 - 10:12, kaže:
vidi, vidi! pa to je straobalno dobro resenje! to da se stavi kao sticky ovde u IT! barem ja za to nisam znao...odlicna ideja
#10
Odgovor 23 November 2011 - 12:10
#11
Odgovor 23 November 2011 - 12:16
Sipi, za 23 November 2011 - 12:10, kaže:
Tako je, samo ime fajla treba da bude autorun.inf
Baš tako. Mea culpa.
Ispravio, a zadržao i onaj stari, za svaki slučaj. Neće meni tu da se startuje šta kako oće...
Ovaj odgovor je uređen od ManicP: 23 November 2011 - 12:18
#12
Odgovor 23 November 2011 - 12:26
@ManicP
Kako dobar tip, odlično, hvala za ovo!
#13
Odgovor 23 November 2011 - 12:40
ManicP, za 23 November 2011 - 12:16, kaže:
Bilo kakvo izvrsavanje sa spoljnih uredjaja (CD, USB diskovi i sl.) moguce je spreciti polisom. Evo kako:
1. Klik na "Start", "Run", i ukucaj "Gpedit.msc".
2. Navigiraj do "Computer Configuration/Administrative Templates/System"
3. Promeni "Turn off Autoplay" properti na "enabled"
4. selektuj "All drives"
5. restartuj PC
ILI LAKO, IL' NIKAKO
#14
Odgovor 23 November 2011 - 13:13
Uspesno sam pobio g.... na hardu i problem resen. Hvala svima na interesovanju i savetima.
Moderatori se mogu osecati slobodnim da promene naziv teme i usklade ga sa korisnim uputstvima koja su data u diskusiji tako da i sira zajednica ima neke fajde od ove price.
lupas bzvze
#15
Odgovor 28 November 2011 - 19:19
Instalirao sam trial kaspersky, ocistio je desetak virusa.
Trial verzija radi mesec dana.
Par dana sam ga zbunio vracanjem datuma na kompu, pa mi javljao da ce da radi jos 29 dana.
Medjutim, ipak razmislja. Danas ukapirao fazon...
Ima li neko boju ideju, mislim, hmhm moze i na pp
lupas bzvze
#16
Odgovor 28 November 2011 - 19:23
samo reci koji je u pitanju
KAV 2010 ?
shiljnem ti proggic koji obrise registry da je bio na trial , pa ga onda opet trialnujes
i tako svaki mesec ......
KAV 2010 ?
#17
Odgovor 28 November 2011 - 23:07
lupas bzvze
#18
Odgovor 28 November 2011 - 23:14
poslato na yahoo
nesto preko 3MB
potvrdi prijem i probu
nesto preko 3MB
#19
Odgovor 28 November 2011 - 23:18
izem ti yahoo i onoga ko ga jos koristi
govno odbija *.rar file koji je pod passwordom
imas PP
imas PP
#20
Odgovor 29 November 2011 - 00:37
ajoj, pa rekoh ti da javis..skini 2011 ver i dobices sta treba na pp, samo me podseti
Slične Teme
To Szeged or not... :)nova roba mora da se proba |
General Off Topic | ಠ_ಠ |
Boxnotes |
Zvucnici | chakija |
Help, kako povezati Mundorfe... |
Solid State | milovan1963 |
SINEVOICE - or not? |
Hi-Fi audio | Blade |
Zvucnici Audio Note AN-J |
Oglasi | anubisgrau |
0 Korisnik (a) čita ovu temu
Pristupi
Registruj se
Nazad na vrh
