Pređi na vezu
Pure updates Classic DAB radio with Listen Later feature
  • Please log in to reply
Nema odgovora na ovoj temi
#1
Audiofil
Audiofil
    Početnik
  • Član
  • Pip____Pip____
  • 428 Poruke
  • Gender:Male
    Serbia
The Pure One Classic Series II has had a lick of paint and a bit of an upgrade with new 'Listen Later' functionality added to the DAB radio.
The play/pause button can be used to pause live radio as well as having the ability to schedule a recording – be it a one-off or a recurring show – using the clock programming function.
There isn't much memory on the radio, so you can only store one recording at a time and the length of the programme you can record depends on the bit rate of the station broadcasting it (but it's generally somewhere between 30 and 180 minutes).
EPG-less
Safe to say, if you're looking for something that uses an electronic programme guide (EPG) to schedule multiple recordings, this isn't the radio for you.
But it's not a bad little DAB for what it is; you can use batteries or the mains to power it (or an optional rechargeable pack from Pure that will set you back £30), and its LCD screen offers all the usual information.
There's also an MP3 input jack, clock-timer, space for 30 station presets and comes in black and white finishes.
If this tickles your fancy, the Pure One Classic Series II hits the shops this month, with a UK price tag of £64.99.
View the full article
Slične Teme Sakri
0 Korisnik (a) čita ovu temu
