Novosti iz Sonido radionice
Zen Mod
dobio sam nesto informacija o novim stvarima iz Sonido radionice .zasad toliko - sto vidite na slikama dakle - dva 12" drivera - SWR300 i SCW300kad budem imao vise , postovacu ovo je slika SWR300 drivera i dve BR kutijeedit:dok ne dobijem data za driver od Varge - dodajem pokupljeno sa neta
Istvan u mailu :
Hi Choky, Here such news: 1.Wide range Speakers SWR 145-8/ALNiCo, SWR 250-8/Ferrit, SWR 300-8/Ferrit. 2.Two-way system SFR 175-8/A + SCW 300-8/Ferrit with the dividing filterin 140 Hz. 3.In the end of this year will be with textiles spirit. 4.In the beginning of next year will be Field-Cool speakers and as alsooval 6x9". Zoltan will write to you about all news. Best Regards, Istvan Varga
btw. Istvan is old geezer - Brain of operation ........ Zoltan is youngster :rolleyes: - Varga Junior
.... inace da razjasnim malo nomenklaturu :SFR - niski Q faktor - pogodni za hornSWR - visi Q faktor - OK za BR , Onken i ostale TL derivativeSCW - evidentno bass zvucnjaci - koristeni kao helperi ........cim dobijem datasheets i grafove , kao i cenovnik - postujem
SCW 250 su, prema podacima na sajtu, 15000 forinti što je tačno 52 evra. SCW 300 su 60 evra. Isplati se kupiti ih i probati definitivno...
PRODUCTS PRICE LIST 2010.
SINGLE DRIVER
SFR series full-range design for back-loaded horn application
SFR 145-8/Ferrit 90,-EUR
145-8/ALNiCo 110,-
175-8 128,-
175-8/A 146,-
200-8 173,-
200-8/A 193,-
SWR series wide-range design for bass-reflex application
SWR 200-8/Ferrit 163,-
200-8/ALNiCo 188,-
250-8/F 192,-
300-8/F 200,-
SCW series paper cone bass-and-middle range driver for bass-reflex application
SCW 300-8/F ( 12”) 96,-
SCW 400-8/F (15”) 146,-
SFR 175/A + SCW 300/F - 498,-
SFR 200/A + SCW 400/F - 596,-
Choky,
The specified prices together with delivery, except for set SCW 300,SCW
400.
Istvan Varga.
data
SCW-300-8 (12") Le 0,61 mH / 1KHz
SCW 400-8 (15") Le 0,92 mH .
napomena - nisam jos dobio zvanicne datasheet-e - ovo prenosim sa ruskog foruma , pa pretpostavljam da to nisu finalni parametri
kad dobijem finalne - editovacu post ....... al' i ovako je OK da se dobiju neke okvirne smernice
Ma ja bi se plašio da kupim te 15-ice... Mada 12-ice i 10-ke mi izgledaju sasvim pristojno. Da imam sobu od jedno 40-50 kvm onda 15-ice bez pogovora :)
Ма одлучи се кад престане дејство Зеноваче,немој журити :drinks:
Choky,
400.
Istvan Varga.
trazio sam da mi posalju cenovnik na njihovim vratima , te ga objavljujem kad ga dobijem
Ma ljudi nemojmo biti uskih pogleda. Danas čitam da je Fidelinka otišla u stečaj... Eeeeej, FIDELINKA :connie_nutzo: To je, za one koji ne znaju, ona velika fabrika u Subotici u kojoj se proizvodi brašno, hleb, testenine. Ono osnovno za jelo.Lopovi spustili vrednost da bi je neko kupio...PU... Kakva crna Ei fabrika. U gorem smo mi sosu nego što vidimo i mislimo.
