Welcome to diyAudio.rs
stein
DIY system by Stein & Co.
680 posts in this topic
Pa valjda ce jos neko piti pozvan na prezentaciju, pa da i oni iznesu svoje subjektivno misljenje o zaista predivnom sistemu ukljucujuci i frizider :moil:<_<
Share this post
Link to post
Share on other sites
SlatkiaAko budeš počastvovan pozivom na prezentaciju sistema, nemoj propustiti priliku da se snabdeš kvalitetnim elementima u Bačkoj Topoli.Imaju odlične kulene i kobasice, sve originali, nema lažnjaka.Biće tvoj frižider veseliji nego Steinov. :moil:
E posetili smo mi taj deo Backe Topole i nisu nas razocarali a pogotovu na salasima <_<
Share this post
Link to post
One more recent review translated by our fine google translation service. I did some correcting because it would only make people laugh. I can't imagine what would it do if translated to Danish... <_<
Did correct the woofer size. Not 18cm, in fact, the mounting hole is 146mm. So, read on...
Stein bogami us fine upgraded.
These new panels and subwoofers are very good ... Unlike the old, which for my taste was too light, the new panels sound "just right" as our French brothers would say.
The stage was huge, in fact limited only by the dimensions of the room (that is to say that they have more space to breathe, would be more luxurious, IMHO). Altitude presentation is something that I still have not heard of the traditional boxes. Host says that is normal because they have practically almost 2m high panels and broadcast by the sound of the entire height. This is the slope with the postulate on the spot the source of the sound but to me this is any fenomenalno experience ...
Completely different sound on the last set-referred, far more relaxing and unobtrusive. Bas is a great track panels, and the speed and definition. Small complaint in the same line-the ultimate Slam that I may expect from the 16 pieces of 16cm (6.5") and Peerlesa not go to podrumskih (cellar deep) 20Hz (Stein estimate of 40Hz). No, actually they were set free in space, when set in the Listening to the floor and closer to the back wall (if the goal) probably will be to improve. And then it is Stein (after the x-th phone call, my better half to come home) and to let play Yello, and hell, denied my dissatisfaction with bass and nearly led to less family strife
What I have heard of Stein is almost diametrically opposite, than the smaller panel. Darker sound (not measure), a huge sweet spot (at the manufacturers with a lower panel is to be micro position, sweet spot is a practical minimum), and somehow, the lack of thinking about the crystal clear high or medium tones ... Somehow, I was charged seciram to music analysis that I have something wrong or anything surplus. As to our friend from Nis defined better than me ...
At the end of me, but almost, and most important, the facility disappear in the space for the memory!
Behold, there is likely to merit a class powered by F5, preamp is Treshold ... not a bit naive. That do not know, would mean that some taykun. And what is DIY!
Bravo!
Still needs to be repaired sense-wise... the translation...
Still not finished, more to come. The Poor Serbian's USB DAC is undergoing testing and will be a part of this system.
... :moil:
Share this post
Link to post
@domaći igrači:Kazu da rodbinu ne mo
Share this post
Link to post
Da nije malo mnogo kubik za prezentaciju sulundara <_<
Kubik je minimum, tol'ko treba za "burn-in", sto kazu: da se usvira :moil: Ja kad resim da dodjem, donosim brikete i antracit, da dignemo bias k'o u Aleph-u :idea:
Share this post
Link to post
Pa dobro, onda buteljku vina (može i neko uvozno Talijansko ili Vrancusko, ne mora domaća kiselica, mislim, za "usviravanje"...) pa mu pokažem kako pliva riba... Ili recimo kilo mlevenog pa mu pokažem kako radi USB-roštilj-ćevap-DAC :moil:
Share this post
Link to post
tol'ko treba za "burn-in", sto kazu: da se usvira <_<
Pa kolko onda za "burn-out", sta ce reci Zeleni za secu sume :moil:
Share this post
Link to post
Slusanje elektrostatika je za mene uvijek bio poseban uzitak, a prvi pravi vrhunski zvuk u zivotu čuo sam iz malih Apogee ribona sa cijevnim pojačalom u A klasi 8W.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
